Подключение лимитов к плате управления MPC6535
Bezot
, 30 Июл 2011 03:18
MPC6535 Выход за лимиты
Сообщений в теме: 30
Отправлено 30 Июль 2011 - 03:18
Подскажите как подключать лимиты к плате управления
там по пять клемм на каждую ось.
1. ELX+
2. ELX-
3. ORGX
4. GND
5. 24V
1. ELX+
2. ELX-
3. ORGX
4. GND
5. 24V
Отправлено 16 Август 2011 - 13:28
Вот, добыл некоторую информацию.
Кто может довести её до конца?
4.3 4-axis Limit Interface (6pin 3.81mm)
Z/U-axis Limit Interface Z/U-Lim
Pins Definitions
1 5V GND (Output)
2 U-,U-axis moves to the limit of 0 coordinate, and corresponds to D14 indicator.
3 U+,U-axis moves to the limit of the maximum coordinate, and corresponds to D13 indicator.
4 Z-,Z-axis moves to the limit of 0 coordinate, and corresponds to D12 indicator.
5 Z+,Z-axis moves to the limit of the maximum coordinate, and corresponds to D11 indicator.
6 5V-1K resistor pulled up or 5V is selectable (Output); when JP3 jumps across Pin 1 and 2, Pin 6 is 5V; when JP3 jumps across Pin 2 and 3, Pin 6 is 1K resistor pulled up to 5V.
X/Y-axis Limit Interface X/Y-Lim
Pins Definitions
1 5V GND (Output)
2 Y-,Y-axis moves to the limit of 0 coordinate, and corresponds to D10 indicator.
3 Y+,Y-axis moves to the limit of the maximum coordinate, and corresponds to D9 indicator.
4 X-,X-axis moves to the limit of 0 coordinate, and corresponds to D8 indicator.
5 X+,X-axis moves to the limit of the maximum coordinate, and corresponds to D10 indicator.
6 5V-1K resistor pulled up or 5V is selectable (Output); when JP2 jumps across Pin 1 and 2, Pin 6 is 5V; when JP2 jumps across Pin 2 and 3, Pin 6 is 1K resistor pulled up to 5V.
◆ In the PC software of this mainboard, you can select the support to the limit polarity, that is, if the axis moves to the limited position, it will trigger a low-level signal, and the LED corresponding to each limit will light up; when the axis moves far from the limited position, it will trigger the high-level signal and the limit indicator will go out. On the contrary, if the axis moves near to the limit, it will trigger the high level; if it moves far from the limit, it will trigger the low level and the limit polarity is plus.
Вот ещё таблица из мануала
Pins Definitions
1 5V GND (Output)
Pins Definitions
1 5V GND (Output)
Отправлено 16 Август 2011 - 22:59
Неужели ни у кого гравёра нет, чтобы открыть крышку и посмотреть?
#5
Отправлено 16 Август 2011 - 23:05
кронечно есть, я на тему не подписан ))) завтра будет времечко гляну
#6
Отправлено 17 Август 2011 - 02:38
Жаль пиво интернетом не распространяется...
Тогда попутно вопрос- (раз уж крышку вскывать)
Из разъёма аутпут платы 6535 крайний вывод air-blow
(который подключается к чему-то под названием air-blow control)-
это не пневмоклапан, который включает/отключает подачу воздуха под линзу?
И если да, то каков там выходной ток? (В смысле сразу на клапан можно или через реле?)
#7
Отправлено 17 Август 2011 - 11:24
это не пневмоклапан
програмно реализована эта функция, но на практике - дует всегда. Да и не к чему это ИМХО, не вижу плюсов и минусов.
ps до станочка еще не добежал )))
#8
Отправлено 17 Август 2011 - 12:56
Плюсы огромны!!!
При резке бальзы на нервюры подаётся СО2, а баллон
почти 340 гривень без поверки стоит.
Кроме того- вырезанная нервюра не определяется весами и очень
легко сносится струёй и может снова попасть под огонь или
сорвать лист.
Поэтому было бы целесообразнее управлять потоком ( или
давлением) хотя бы при переходах от контура к контуру.
Полный вес собранной нижеприведённой модели- максимум 45 грамм
сорвать лист.
Сообщение отредактировал Bezot: 17 Август 2011 - 13:10
#9
Отправлено 17 Август 2011 - 13:24
бальза и без газа на ура режеться, а есть сопла с регулируемой подачей воздуха, например при гравировке очень важно....
#10
Отправлено 17 Август 2011 - 13:38
Да, но здесь очень важно не опалить край- тогда точнее геометрия после обтяжки и клеевое соединение прочнее.
Опаленный край на порядок слабее
#11
Отправлено 17 Август 2011 - 13:43
торговали раньше лазеркой на MPC 05 - там есть функция как на фрезере по средней линии, по наружней и внутренней контуру (ТОЛЕРАНС) так вот способ обработки есть , а нехера не работает, только по средней. На 6535 не нашел тоже такой фишки, только по средней, если нашли в софте, подскажите ....
ps кстати хороший вопрос, кто как бореться с этой лабудой в ноль то не вырежешь никак на лазере деталюшку (опять же незнаю как на ГЦЦ).
Сообщение отредактировал sinner: 17 Август 2011 - 13:44
#12
Отправлено 17 Август 2011 - 14:14
Как же я подскажу, если ещё не подключил 6535?
Все годы до этого - в стопку и лобзиком.
Потом бруском доводим.
Но прогресс для того и придумали, чтоб на месте не стоять.
И если на тренировки брать не одну, а десять бойцовок, да
с себестоимостью и временем изготовления в разы ниже- результат
будет.
По крайней мере весь китовый китай собирается очень и очень
прогнозируемо и хорошо. Возможно они изначально делают поправки в
лекала и режут а ноль, как есть. Там единственная проблема с самим
материалом, хранением и доставкой.
будет.
#13
Отправлено 20 Август 2011 - 14:20
Мне хотя бы намёк.
Заглянуть в конец направляющей и глянуть какие контакты концевика задействованы
и открыть крышку посмотреть на какие клеммы приходят проводки.
#14
Отправлено 22 Август 2011 - 16:04
Изобретаем велосипед
Не зная внутренностей черного ящика под названием контроллер можно придумывать десятки и сотни вариантов подключения концевиков.
Причём согласно блок-схемы производителя все они будут абсолютно правильными.
Однако гарантированно будут неправильными на самом деле
#15
Отправлено 22 Август 2011 - 16:42
Ну вот и я прискакал...будем помогать
6535 значится, хм у нас стоит сейчас лазерка 1500 на 2500 на плате
Вот такой
К фоткам пояснения нужны?
Вот такой
#16
Отправлено 22 Август 2011 - 18:03
Супер!
Просто супер!!
Да, некоторые пояснения нужны.
1. Немного странно, что сечения проводов на лимитах почти в три раза отличаются,- там ведь совершенно нет тока по-идее, зачем такой толстый провод на иксах?(но это так, не важно)
2. Было бы замечательно посмотреть фото на концах осей- места где эти проводки заканчиваются концевиками. Тогда картина была бы полностью ясной.
3. Ну и параллельно возник вопрос: можно фото клеммника блока питания трубки? А то фото идёт вразрез с документацией на БП и контроллер
4. Не увидел всунутой в контроллер флеш-брелка из набора- это правильно?
5. Аут-разъём пустой. А там ведь индикаторы, управление воздухом... Или они не важны?
Просто супер!!
Сообщение отредактировал Bezot: 22 Август 2011 - 18:10
#17
#18
Отправлено 23 Август 2011 - 13:50
Спасибо, фото сняли множество вопросов и обусловили
серъёзный прорыв в подключении 6535.
Но не все и не полностью.
Исследование фото показало, что от контроллера отходят
чёрный, синий, коричневый и серый провода, а до концевиков
доходят в-основном черные. Подмешивается также красный вдоль
направляющей (там ему вроде как и идти-то некуда дальше).
Возможно гдето- в станке есть распределительная коробка,
какой-нибудь блок реле или ещё что-то, в чём теряется след
проводов от контроллера.
#19
Отправлено 23 Август 2011 - 13:53
Нету ничего там - концевики 3 провода имеют +5 вольт и еще 2 и все к маме...
#20
Отправлено 23 Август 2011 - 14:41
В смысле 24в (а не 5) вольта от контроллера, да?
Выходит ORG нормально замкнуто сидит в земле и по краям
осей переключается в плюс питания, правильно?
Темы с аналогичным тегами MPC6535, Выход за лимиты
