Постпроцессор ArtCAM в LinuxCNC (файл ngc)
Постпроцессор Постпроцессор ArtCAM
Сообщений в теме: 2
#1 OFFLINE   Alexander_71
Alexander_71
  • Из:Nevinnomyssk
Отправлено 30 Ноябрь 2016 - 18:40
Доброго дня!
Возник вопрос, как сохранить УП созданную в ArtCAM с расширением NGC для linux CNC.
Вроде внимательно искал на форуме но не нашел.
Помогите если можно.
Спасибо.
#2 OFFLINE   Dmitriy.Samarskiy
Dmitriy.Samarskiy
  • 25 сообщений
Отправлено 22 Июнь 2018 - 12:37
;LinuxCNC PostP file w/ g2&g3 arc moves in MM
;Saf2018
;GW 1/21/08 created for MM (metric) users
; For tool changer via macro use ATC PostP
;GW 10/25/09 Added toolnumber and tool description for Start & New Segment
;GW 10/25/09 Added New Segment to allow forced RPM change on same tool #
DESCRIPTION = "Linux(*.ngc)"
FILE_EXTENSION = "ngc"
UNITS = MM
; Cariage return - line feed at end of each line
END_OF_LINE = "[13][10]"
; Spindle Speed
FORMAT = [S|@|S|1.0]
; Feed Rate
FORMAT = [F|#|F|1.0]
; Tool moves in x,y and z
FORMAT = [X|#|X|1.3]
FORMAT = [Y|#|Y|1.3]
FORMAT = [Z|#|Z|1.3]
; Arc Center Coords
FORMAT = [I|@|I|1.3]
FORMAT = [J|@|J|1.3]
; Home tool positions
FORMAT = [XH|@|X|1.3]
FORMAT = [YH|@|Y|1.3]
FORMAT = [ZH|@|Z|1.3]
; Tool Number
FORMAT = [T|@||1.0]
; Set up program header
START = "([FILENAME])"
START = "G90G80G21G49"
START = "M6 T[T]"
START = "(Tool Number:[T]) ([TOOLDESC])"
START = "G43 H[T] G0[ZH]"
START = "M3 [S]"
;START = "G04P5"
; Program moves
FIRST_RAPID_RATE_MOVE  = "G0 [X] [Y] [Z]"
FIRST_FEED_RATE_MOVE   = "G1 [X] [Y] [Z] [F]"
FEED_RATE_MOVE         = "[X] [Y] [Z]"
FIRST_CW_ARC_MOVE      = "G2 [X] [Y] [I] [J] [F]"
CW_ARC_MOVE            = "G2 [X] [Y] [I] [J]"
FIRST_CCW_ARC_MOVE     = "G3 [X] [Y] [I] [J] [F]"
CCW_ARC_MOVE           = "G3 [X] [Y] [I] [J]"
NEW_SEGMENT_POST_TOOLCHANGE="(Tool Number:[T]) ([TOOLDESC])"
NEW_SEGMENT_POST_TOOLCHANGE= "M3 [S]"
;Setup Toolchange Commands
TOOLCHANGE = "G0[ZH]"
TOOLCHANGE = "M5"
TOOLCHANGE = "G49"
TOOLCHANGE = "M6 T[T]"
TOOLCHANGE = "G43 H[T] G0[ZH]"
; End of file
END = "G0[ZH]"
END = "G0[XH][YH]"
END = "M5"
END = "M30"
END = "%"
; M30 = program end and rewind
#3 OFFLINE   pavelshakal
pavelshakal
  • 17 сообщений
  • Из:РБ. Минск
Отправлено 13 Сентябрь 2018 - 13:02
установил данный пост процессор и Lcnc пишет ошибку, через эмулятор проверил откуда то появилась полу дуга из-за которой ошибка! в чем  косяк в моих руках или ?
Темы с аналогичным тегами Постпроцессор, Постпроцессор ArtCAM
