G - Code configuration file
; Соловьев Юрий 23.12.2005г.
DESCRIPTION = "ДЯТЕЛ (mm) (*.U00)"
FILE_EXTENSION = "U00"
UNITS = MM
; Cariage return - line feed at end of each line
END_OF_LINE = "[13][10]"
; Block numbering
LINE_NUM_START = 0
LINE_NUM_INCREMENT = 10
LINE_NUM_MAXIMUM = 999999
; Set up default formating for variables
; Line numbering
FORMAT = [N|@|N|1.0]
; Spindle Speed
FORMAT = [S|@|S|1.0]
; Feed Rate
FORMAT = [F|#| F|1.0]
; Tool moves in x,y and z
FORMAT = [X|#| X|1.2]
FORMAT = [Y|#| Y|1.2]
FORMAT = [Z|#| Z|1.2]
; Home tool positions
FORMAT = [XH|@|X|1.1]
FORMAT = [YH|@|Y|1.1]
FORMAT = [ZH|@|Z|1.1]
; Set up program header
START = "/ROC/1"
START = "S1000 M3"
START = "G0 G90 G54 [XH] [YH]"
START = "G43 H1 [ZH] M8"
; Program moves
RAPID_RATE_MOVE = "G0[X][Y][Z]"
FIRST_FEED_RATE_MOVE = "G1[X][Y][Z][F]"
FEED_RATE_MOVE = "[X][Y][Z]"
; Setup Toolchange commands
TOOLCHANGE = "[N]T[T]M6"
TOOLCHANGE = "[N][s]M03"
; End of file
END = "M17"
END = "M30"
END = "%"
