Looking for a DSP board
Сообщений в теме: 7
#1 OFFLINE   vito 90
vito 90
  • Из:tunisia
Отправлено 23 Сентябрь 2019 - 00:19
Hi guys, (i'm sorry, i only speak English)
i'm looking for an old DSP board (i don't know what model it is)
I can't find this type of Board anywhere, can anyone please help me !
Thanks
#2 OFFLINE   vv92
  • 9 354 сообщений
Отправлено 23 Сентябрь 2019 - 00:29
richauto rznc 0401
#3 OFFLINE   vito 90
vito 90
  • Из:tunisia
Отправлено 23 Сентябрь 2019 - 00:48
richauto rznc 0401
Thanks, But i'm looking for the same board card
#4 OFFLINE   Gosha
Отправлено 23 Сентябрь 2019 - 16:12
I hope you lucky guy, because this boards not manufactured last 20 years.
Good luck!
#5 OFFLINE   3D-BiG
  • 14 536 сообщений
Отправлено 23 Сентябрь 2019 - 16:24
If the problem is in the patch board, and not in the console itself, then it may be cheaper to repair the patch board than to find a new working one, because it contains only typical non-programmable components, which means that it is enough to understand which component is faulty and replace it, how your old switching board will start to work ... The text was written through a google translator, so it may not be very competent, but alas, I don’t speak English.
#6 OFFLINE   Gosha
Отправлено 23 Сентябрь 2019 - 16:42
Вадим, там переключить контакты и перейти на 0501 дело пары часов.
Очевидно у тунисского коллеги либо нет денег на апгрейд, либо совершенно нет знаний на перекоммутацию.
Склоняюсь ко второму варианту. В этом случае никакой совет ему не поможет.
#7 OFFLINE   vito 90
vito 90
  • Из:tunisia
Отправлено 23 Сентябрь 2019 - 16:50
Thank you for replying,
The problem is from the board, (when i connect the DSP controller to it, it doesn't work,  it works only when i connect to the PC with the USB cable)
if i buy the  richauto rznc 0401 board, how will i connect the wires !!
#8 OFFLINE   3D-BiG
  • 14 536 сообщений
Отправлено 23 Сентябрь 2019 - 20:46
In the cable connector, the following pin assignment. I took the remote control from the documentation for 0401.  I didn’t find any documentation for your patch card, but there is a remote control ...
pin    signal      Function specification
1        VCC 5V   +5v
2     X PULSE+  X axis pulse+
3     X DIR+       Direction of X axis+
4     YPULSE+  Y axis pulse+
5     Y DIR+       Direction of Y axis+
6     Z PULSE+ Z axis pulse+
7     Z DIR+      Direction of Z axis+
8     C PULSE+ C axis pulse+
9     C DIR+      Direction of C axis+
10   CADI 11+  Figure inputting terminal
11   CADI 10+  Figure inputting terminal
12   CADI 9+    Figure inputting terminal
13   CADI 8+    Figure inputting terminal
14   VCC 5V    +5v
15   CADI 7+    Figure inputting terminal; Cut adjusting device signal input+
16   CADI 6+    Figure inputting terminal
17   CADI 5      Figure inputting terminal
18   CADI 3      Figure inputting terminal
19   CADI 1      Figure inputting terminal; origin of Y axis sensor signal
20   AVDD I      IO positive shared terminal
21   AVDD O    IO positive shared terminal
22   CADO 1    Figure outputting terminal
23   CADO 3    Figure outputting terminal
24   CADO 5    Figure outputting terminal
25   CADO 7    Figure outputting terminal
26   GND         GND
27   X PULSE- X axis pulse-
28   X DIR-      Direction of X axis-
29   Y PULSE- Y axis pulse-
30   Y DIR-      Direction of Y axis-
31   Z PULSE- Z axis pulse-
32   Z DIR-      Direction of Z axis-
33   C PULSE- C axis pulse-
34   C DIR-     Direction of C axis-
35   CADI 11- Figure inputting terminal
36   CADI 10- Figure inputting terminal
37   CADI 9-   Figure inputting terminal
38   CADI 8-   Figure inputting terminal
39   GND       GND
40   CADI 7-  Figure inputting terminal; Cut adjusting device signal input-
41   CADI 6-  Figure inputting terminal
42   CADI 4   Figure inputting terminal
43   CADI 2   Figure inputting terminal; origin of Z axis sensor signal
44   CADI 0   Figure inputting terminal; origin of X axis sensor signal
45   CADGND IO negative shared terminal
46   CADGND IO negative shared terminal
47   CADO 0 Figure outputting terminal
48   CADO 2 Figure outputting terminal
49   CADO 4 Figure outputting terminal
50   CADO 6 Figure outputting terminal
Thus, at terminals 1 and 14 there should be +5 Volts relative to terminals 26 and 39.
It remains to be understood why there is no such voltage on the board on these conclusions ...
It is enough for the electronic engineer to make sure that there is a supply voltage on these terminals, and if so, then check the cable for serviceability, and if not, it will not be difficult to figure out why the supply voltage does not come to these terminals ...
