Здравствуйте, при включение станка возникла следующая проблема
Станок Beaver 25 после настройки сети и перезагрузке
выскакивает такое горе
Intel®82559ER Fast Ethernet Driver u4.11.021400
Copyright 1995-2000,Intel Corporation .All Rights Reserved
Defaulting to NIC found in slot 0x0006
Intel GD82559ER Fast Ethernet Controller
Supports 10BASE-T and 100BASE-TX
Microsoft DOS TCP/IP Protocol Driver 1.0a
Copyright© Microsoft Corporation,1991. All rights reserved
Copyright© Hewlett-Packard Corporation ,1985-1991 All rights reserved
Copyright© 3Cpm Corporation ,1985-1991 All rights reserved
Microsoft DOS TCP/IP NEMM Driver 1.0
The command completed successfully.
MS-D0S LAN Manager v2.1 Netbing
Initializing TCP/IP via DHCP.....
